redundant thread, I know: Synthetic for my first oil change?
neek21
Car: '10 Moonlight White/Graphite interior G37x, Premium/Navigation...
going in for my first oil change [3750] and was wondering what the consensus was, synthetic or regular oil for my first [and subsequent] oil changes...thanks for the help folks!!!
soul_hfk
Car: 2010 G37xS---08 QX56
in my other G i changed to synthetic on her 1st oil change the new 1 i forgot to say to put the synthetic in so ill make the change the next time. but yea i would change it over for your first
joe603
Car: 2014 Durango R/T
I did synthetic on the second oil change...but that was at 3k miles. I say do it!
telcoman
neek21 wrote:going in for my first oil change [3750] and was wondering what the consensus was, synthetic or regular oil for my first [and subsequent] oil changes...thanks for the help folks!!!
I think it is a waste of money
Telcoman
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
i changed immediately.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I changed to synthetic at the first oil change, at 3750. Car has been tracked multiple times and currently has 59k miles on it. Runs as good as new. I say go for it.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Local Infiniti service dept. told me to change it at the first change (this was my new 05 Sedan). Do it!! :mike
neek21
called the dealership, talked to the service department and got an appointment for Saturday morning....when i told the manager i wanted to put synthetic in [first oil change, 3750], he tried to talk me out of it, said the "seals hadnt set in yet", or something like that..he wanted to put regular, or the same type of oil that came with it from the factory...he then said I could bring whatever oil i wanted and they would put it in for me, as well [ :gotme what gives??]....any ideas folks??
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
neek21 wrote:called the dealership, talked to the service department and got an appointment for Saturday morning....when i told the manager i wanted to put synthetic in [first oil change, 3750], he tried to talk me out of it, said the "seals hadnt set in yet", or something like that..he wanted to put regular, or the same type of oil that came with it from the factory...he then said I could bring whatever oil i wanted and they would put it in for me, as well [ :gotme what gives??]....any ideas folks??
That has some truth to it, but typically that is what the "break-in" period is for...usually the first 1000 miles. If you wait until 3750 miles for your first oil change, the rings should well be sealed by then.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
I change oil on the first 1000 miles with 'dino' oil, then synthetic from 3000 miles onwards.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Synthetic, AMSOIL at that.
Amays U G37S
Car: shoes
Ya you have to run synthetic in these motors because they are not designed to be ran with conventional. These motors are built in an air tight, white suit, closed off room. Not in the middle of the open assembly line.
Stick with synthetic, trust me.
neek21
Plan on putting Pennzoil Platinum in...let the arguments begin!!! :chuckle: [lol]
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Amays U G37S wrote:Ya you have to run synthetic in these motors because they are not designed to be ran with conventional. These motors are built in an air tight, white suit, closed off room. Not in the middle of the open assembly line.
That's not true. Obviously, synthetic is recommended, but it's not required. Take a look at your owner's manual. It makes no mention of synthetic oil.
If it was required (like it is in the GTR), it would say so on the oil filler cap and also in the owner's manual.
cbak999g35
Car: 2007 G35
1995 Mustang Cobra
2007 VW Passat wagen - wife's car
Right...recommended but not required. Compare it to premium vs. regular gasoline. All in all, it's about $13 per oil change and under normal driving conditions, that's about $40 a year, to do synthetic changes (if you change your own oil). I can afford that. I get Mobil 1 at Wal-Mart for $23/5 qt jug. I'm not a Wal-mart fan, but it's cheap.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
cbak999g35 wrote:Right...recommended but not required. Compare it to premium vs. regular gasoline. All in all, it's about $13 per oil change and under normal driving conditions, that's about $40 a year, to do synthetic changes (if you change your own oil). I can afford that. I get Mobil 1 at Wal-Mart for $23/5 qt jug. I'm not a Wal-mart fan, but it's cheap.
Actually, regarding fuel, depending on the year of your vehicle, premium *is* required. It says "Premium Unleaded Only" on the filler door and also says minimum 91 octane in the owner's manual. It will run on lower octane, but can cause damage to the engine if you run it all the time. But that's a whole different subject...
And I wouldn't make the comparison to fuel anyway. Premium fuel, when not required, is a complete waste of money. It has nothing to do with the quality of the fuel, but rather the latency to ignite. The difference in oil between synthetic and natural (or "dino") oil is quality related. Polymers in synthetic oils are designed to not break down as easily, which means it's longer lasting and better protection against metal parts wearing. Which is also why it's harder to seat new rings with synthetic oil, because it doesn't allow much wear (which is needed to seat rings). But going back to the original subject, rings should be well seated by 3750 miles, so there shouldn't be an issue. If you were changing oils at 1000 miles on the engine, you'd be better off waiting before the switch to synthetic.
Amays U G37S
Car: shoes
It doesn't recommend using 91... I use 89 anyways
our pumps are 87 89 91
I unno what your pumps are
But i run seaform every 4 gas tanks. I have a problem with this crappy 89 i bought somewhere forget where
ugh!
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Amays U G37S wrote:It doesn't recommend using 91... I use 89 anyways
ugh!
You should take a look at your manual again. For 2008, it recommends 91 for the sedan, but states it as a requirement for the coupe. In fact, here is exactly what it says:
VQ35HR engine
INFINITI recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96).
If unleaded premium gasoline is not available, you may use regular gasoline with an octane rating of at least 87 AKI number (Research octane number 91), but you may notice a decrease in performance.
VQ37VHR engine
Use unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96).
If premium gasoline is not available, unleaded regular gasoline with an octane rating of 87 AKI number (Research octane number 91) may be temporarily used, but only under the following precautions:
