http://www.speedwaymotors.com/....html
came up with this with a quick search, prob wouldn't know about it except I had a similar problem with stock KA exhaust when I first did my swap. you'll still need to weld appropriate size flanges on the ends, and maybe shorten the exhaust before the cat(doing something like this will add a few inches). you could use this and a short section of pipe to make a reducer test pipe.
Another option is fill in the rest of the exhaust with 3" pieces, cat, manifold, downpipe. This is a tricky option though, I think to do it you'd get a 3" downpipe and cat for an SR, then a turbo KA mani and have a 3" pipe to connect them where the turbo would normally go.
an NA KA engine isn't really supposed to be run with a 3" exhaust, thats turbo size piping, so I would suggest you go KA-T or do the SR swap at some point. just my 2 cents though.
