nismostate »
https://forums.nicoclub.com/nismostate-u11758.html
Tue May 04, 2004 5:11 am
Ok, got everything hooked up and did all the wires like heavy throttle said. try to start it but it wont crank. not turning over or anything. No click either. Starter should be fine since I just got it checked. I looked on the troubleshooting section and it said to "Check Main power wiring and start signal wire to ECU". Is the Main power wiring the blue/red stripe and black/red stripe spliced together one? Which one is the start signal wire to ECU? Is it the black/white stripe? Also, I've been told to check the small wire that's on the starter. I tried to crank it when it was getting dark so I just gave up after it didn't crank. What else should I check for?
