redtop wire harness help
Sideways240
Car: Cars girls and food
I got a sr20det redtop cheap because the wiring harness was cut and I've been searching (not too hard) for a used one or if someone sells them modified with out needing a core. Any help would be appreciated.
GroundZero
proimport17
Car: motocross, baseball
Harnesses are for sale on ebay all the time
deftdrummer
Car: cars, drums, music, technology
when you get a harness will anyone work for your engine? Cause harnesses go for about $160 on ebay all the time. Perfect engines with cut harnesses are about $1400 which is REALLY cheap too. Would this work?
GroundZero
theres a guy that works with heavy throttle that takes your harness cuts it, modifies it to work with the sr20, if i remember correctly it was only $100 plus shipping both ways.
MarvynDT
Sorry to threadjack, but which harnesses do you use when doing the SR20det swap? I figure you'll use the SR upper engine harness (from ecu to injectors, etc.) and the lower engine harness (runs along transmission). But what about the harness that runs along the outside of the engine bay (has both fuse boxes and headlight harness)
GroundZero
actually the ka harness can be modified to work for the ka.
Sideways240
Thanks y'all
