Redtop SR20DET build
Ser200sx567
Car: 240sx
Finally have the cash to do up my SR20DET Build. Got a hold of a Short block, and Complete head with coil packs. Bought a IACV, Q45 ignitor chip, coil pack cover. I'm waiting on buying the rest of the odds and ends till i'm ready to drop it in the 240sx.
I'm building this engine from scratch, I do not have a JDM swap rather piecing everything together including the actual castings using Nicoclub, SR20Forum, and Ebay. I'll post parts I need here in the future if anyone has something feel free to send me a email at [email protected]
Heres a parts list of stuff I got for the engine so far.
Complete S13 Redtop head with valve cover and coil packsComplete S13 Short block with Crank, covers and oil pan
Aftermarket Upgrade Parts Short Block: CP 9.0:1 pistons Eagle H Beams w/arp2000 bolts ACL Race Rod and Main Bearings with ACL thrust washer set 1.2 x 87mm Cometic Head Gasket OEM Gasket set ARP Main StudsARP Head Studs
Valve Train: HKS Step 1 cams (256 Intake 10.5mm lift, 264 Exhaust 10.5mm lift) BC spring titanium retainer kit SI Stainless steel blk nitride valves SI Manganese Bronze guides Tucker Valve seat inserts Stainless steel rocker arm stops
I'm getting the block on the engine stand tonight and going to chase all the threads, clean it up and torque down my main caps with my ARP Main studs. Then the block will be ready for the machine shop.
Does anyone have a good machine shop they would like to reccomend to do a block blueprint That has a Torque plate. I'm looking at buying a torque plate myself, having a couple blocks machined with it and selling the plate when i'm done with it.
Anyone that wants to share some words of wisdom thats what this thread is all about.
Thanks
The Holy Grail of SR20DET Machining, BHJ Torque Plate!!!!
Modified by Ser200sx567 at 1:50 PM 10/21/2008
Modified by Ser200sx567 at 5:28 PM 11/3/2008
Modified by Ser200sx567 at 8:08 PM 11/3/2008
Modified by Ser200sx567 at 12:53 PM 11/19/2008
Modified by Ser200sx567 at 12:55 PM 11/19/2008
Modified by Ser200sx567 at 12:57 PM 11/19/2008
Modified by Ser200sx567 at 12:59 PM 11/19/2008
Ser200sx567
Car: 240sx
Just bought a Q45 90MM Throttle body the otherday, and found a Thermostat housing and heater pipe. Made a few calls and I decided to buy a BHJ Torque plate!!! I'll get some pictures up asap
Disassembled my cylinder head and installed Bronze guides and reamed them out. They are rated for 10,000 RPM. Brining it up to my brother to have the rest of the machine work done. Will have the head built by next week and then have the block machined out and assemble it.
Have a set of new one piece stainless steel valves that are swirl polished and black nitrided.
Modified by Ser200sx567 at 7:21 PM 10/30/2008
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Don't forget rocker stoppers.
MastaYu
Car: 92 Nissan 240SX SE HB
pics?
duffman1278
Car: 89 240sx Hatch, the wildcats!
A "build" thread with no pics......????
Ser200sx567
Car: 240sx
Good call with rocker stopers, putting pics up tonight.
Ser200sx567
Car: 240sx
Has anyone had a set of split fire coil packs? are they worth the money, does it have any horse power show up on a dyno? does it make the engine more reliable?
Ser200sx567
Car: 240sx
The head is in the machine shop right now. I got some custom made valve seats for it since the factory ones were pretty much gone when i got the head. If anyone needs seats i can get you a set of 8 intakes and 8 exhaust for $150 shipped.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Ser200sx567 wrote:Has anyone had a set of split fire coil packs? are they worth the money, does it have any horse power show up on a dyno? does it make the engine more reliable?
I've wondered about this too, if they really make a difference that is.
Ser200sx567
Car: 240sx
for $400 one would hope they help control pre ignition/detonation. It be nice to hear some feed back on the topic. the build is going good. Just getting some details together before i bring the block to the machine shop. The head is already there, it needed Valve seats which are a hard to find item, and the sr20det has a differnt O.D. than the usdm sr20de which kinda sucks but oh well.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
I don't have any specific numbers but a member on this board recently added Splitfire coils to his setup and he had good things to say here : zer...age=4
Ser200sx567
Car: 240sx
seemed to work pretty good for that guy. I'll give them a shot, getting my head gasket this week so i can bring the block to the machine shop now. i'll get before and after pics up asap.
duffman1278
Are you putting the pistons and everything yourself or is the shop doing it?
The reason I ask is to see what tool you're using for putting in the pistons into the cylinder because that one I used for my engine was kinda iffy. I wasn't too happy with it.
Ser200sx567
Car: 240sx
I'm doing the entire assembly myself, If i had the machines I'd do all the machining myself I worked as and automotive machinist before I got my engineering degree. For installing pistons I have this ring compressor, No complaints, works great.
http://store.summitracing.com/...w=sku
Ser200sx567
Car: 240sx
Block and head are at the machine shop, will post pics up when I get them back, and go through the assembly process.
homeslicej2
great to hear now, moar pics!
mjmmx6
Car: 1991 Nissan 240sx sr20det swap, 1993 mazda mx6 Fully Loaded
how much power are you hoping to get when you are complete?
Ser200sx567
Car: 240sx
I'm shooting for 375+ with a GT2876 or 450 with a t3/t4 set up. I'll probally run the GT2876R because i want good mid range power too. I'm hoping bumping up to 9.0:1 compression will aid with that. I'm also using a 1.2mm thick cometic head gasket.
Modified by Ser200sx567 at 12:46 PM 11/19/2008
fast_s13
make sure you grind down the rear arp main bolts otherwise they will hit your oil pan and crack it
Ser200sx567
Car: 240sx
Thanks for the tip, that saves me a big head ache!!
redtop91
fast_s13 wrote:make sure you grind down the rear arp main bolts otherwise they will hit your oil pan and crack it
Are you sure is the bolts that you Grind and not the upper oil pan?
fast_s13
yup i ordered all my parts fom enjuku thats what they told me to do...i also contacted ARP... after i cracked my oil pan
Ser200sx567
Car: 240sx
what did arp do about your cracked oil pan?
fast_s13
nothing i toook iit to a welding shop and got it welded...they didnt charge me anything so i didint complain
Ser200sx567
Car: 240sx
glad to hear you got it running, Which main studs need to be ground?
fast_s13
oh she runs like a raped ape.... its the back two studs thaneed to be ground
Ser200sx567
Car: 240sx
what kind of turbo are you running and what did you do for fuel, and tuning?
What do you guys thing about God Speed Project stuff? Good or bad quality? Should I just by a S15 turbo? gonna run the stock turbo manifold, get it shoot peened and have the flange resurfaced.
Modified by Ser200sx567 at 6:03 PM 11/21/2008
fast_s13
running a stock s14 t28 stock injectors and apexi power fc for tunning
Ser200sx567
Car: 240sx
I want to buy a apexi Power FC. Is it easy to use? I'm going to be getting it dyno tuned professioinally but is it something that I could keep up on too?
fast_s13
its pretty easy to use as long as you have a wideband
