Ser200sx567 »
https://forums.nicoclub.com/ser200sx567-u73699.html
Wed Oct 22, 2008 4:00 am
Sounds like you have a leaky head gasket, White smoke is usually burning coolent. Do you have a Metal/MLS head gasket or head studs installed. Running that much psi can be hard on a stock engine. Sometimes the head gasket will burn through the fire ring, or head might have lifted a bit off the block when it was hitting that much boost.
Oil is usually blue tint of smoke. you might not catch that on a compression test. Run a leak down test then you can see if theres any problems with rings, gaskets, and valves.
Good luck
