Redtop sr to s14 chassis wiring: Question?
outlaw0209
Car: 1995 240sx
Okay, I found all the pinouts I need. I figured out the main components I need to wire from the SR F8, F10, and SR consult port to the F3 plug. My unanswered questions are about the left over connections from the F3 plug. Obviously, I know that I'm not using a consult port, which leaves a group of the wires out, but what about pin #44 (I pinned a red dot next to it) of the IACV.
I'm positive that what I have figured out is enough to get the car started without AC, CC, or a consult port, just want to double check.
Also, what plugs are these and do I even need them (from the KA harness)?
I think the smaller plug with tape is the ambient air temp sensor
But the bigger one, not sure, I'm thinking AC or some type of cluster control.
