Redtop SR. SAFC II reading signal from two MAFs
otterman
I'm hooking up my SAFC II to my red top SR20. I went to the Check Sensor Voltage, it read In-1 and In-2 bothing having volts? The manual says that In-2 is for twin airflow systems (twin turboed).
Is it normal that In-2 has a reading? I double checked my wiring and it seemed good.
while the engine is offIn-1 is at .735In-2 is at .20
I havnt turned the car on yet because I wanted to be sure it was wired correctly first.
otterman
good morning Nico
otterman
afternoon bump
180fan
Car: 89 fastback
why do you have a two maf setup on your afc?
otterman
lol That's what I'm asking.
In my Sens.Cal, which if I'm understanding right, is determines the number of mafs, I have 1 in and 1 out. Which I thought was supposed to set it to 1 maf.
Blown240sx
Car: 1996 240sx
you should have settings of 6 in and 6 out and 1 in 1 out on the other setting.
1 in 1 out is number of MAFs
6 in 6 out is stock SR MAF reading (you can use the apexi manual for all other MAF numbers).
And the second MAF voltage reading is there because there is always some electrical interferrence. even though .2 Volts is a little high I wouldnt worry about it just make sure your settings are correct.
otterman
Blown240sx wrote:you should have settings of 6 in and 6 out and 1 in 1 out on the other setting.
Yeah the settings are good. It just worried me I was getting a reading from a non existant maf. Thanks!
