zachattack_5491 »
https://forums.nicoclub.com/zachattack-5491-u101212.html
Sun Mar 21, 2010 9:15 pm
I posted in the SR forum, got zero replies.
I'm getting code 21 (Ignition signal). I've tested the entire harness, all the way to the ECU. Last thing I checked was the ignitor chip.
When I tested terminal E to ABCD, I got something like 12ohms of resistance.Same result with ABCD to 1234. Can someone test theirs to see if it's the same?
Wayne at Phase2 told me that my SR wouldn't even start if the chip was malfunctioning. But I don't see how else I could get a code 21.
Under no load it struggles to get up to 3000 rpms. Cannot go passed 3000. Idle is rough, but it doesn't stall. I'm running pretty rich I think. I have a small boost leak, which is going to be fixed with a new IC. Also getting code 34 for knock sensor, which is getting replaced. The knock sensor wouldn't cause this right? Any help or ideas would be appreciated.
