redtop s14
SlidewaysScott
Car: 1990 240sx hatch, 1995 240sx sr20det
Ok first off I have searched...and the best topic I found gives a link on how to use the KA harness with SR plugs. I can't do that, the KA harness is cut and mangled. Rather, I am asking if anyone knows how, or has a very detailed step-by-step on how to wire a Redtop harness, to work in an 95' s14? I really need need to get this done ASAP!!!. And again, yes I have used the search button and even googled....
ILikeMy240sx
Car: SR Power
If you are missing a KA harness then you can't go any further without first obtaining a KA harness because you will need some plugs from KA to transfer over to the SR harness.
SlidewaysScott
I have the KA harness...it's just cut into about 3 pieces so I have all the plugs and everything. I just can't really find a step-by-step detailed enough and possibly even with pics to wire a redtop harness for the s14. I'd rather do it myself than send it somewhere so I can learn how to for maybe future swaps and such. Anyone know of a good step-by-step? I should have just kept my coupe..
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
Bump, i really need to know this too.ive got all the wiring diagams and i just cant seem to make it all out when i go to astart wiring it all upredtop sr in a s14 chassis wiring
karmakaze
Car: 98 240sx SE
SlidewaysScott wrote:I have the KA harness...it's just cut into about 3 pieces so I have all the plugs and everything. I just can't really find a step-by-step detailed enough and possibly even with pics to wire a redtop harness for the s14. I'd rather do it myself than send it somewhere so I can learn how to for maybe future swaps and such. Anyone know of a good step-by-step? I should have just kept my coupe..
rule of thumb, if you can't figure it out on your own by looking at the schematics in the FSM then you need to pay someone else to do it.
TanManS14
Car: 1995 240sx
Well I actually saw this link on this very website, and when I saw how clear it was put it on my favorites for when I do my swap.... Here you go, this is about as clear as it gets http://www.frsport.com/sr20det....html
Warped
thats for a s13 redotp or blacktop into a s13 not a s14we need the wiring from a s13redtop to a s14 chassis
TanManS14
Car: 1995 240sx
Its the same wiring harness, and unless its OBD2 should it be different, enlighten me... Which I have an s14 and its obd1 and its possible his is.
Warped
wiring on a s14 and s13 chassis are different
Nismo_Freak
Car: 89 Nissan 240SX
S13 and S14 are completely different.
http://www.camel-towing.com/do...4.htm
If you have a 96+ model S14 you will need to make changes to the above wiring! Follow below link.
http://www.camel-towing.com/do...).htm
Info thanks to my friend Al.
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
I'm really glad I found this thead!! I have a S14 (95) and going to be installing a S13 Redtop into her soon. I've installed my brother CA18DET w/Auto and will be doing a RB25DET into a S13 soon for a friend. (As long as he gets everything to make it complete). Thanks
Warped
hey nismo freak
i've been looking at that sire for help and one thing thats kinda throwing me off is the fact that their wiring in the sr conector ends to the ka F3 plug.now if you dont have the sr power plug male ends what do you hard wire them into?is the ka F3 connector getting power from the sr power plugs or is it giving power to the sr power plugs?
the sr power plugs are on the main harness that he is showing...
OMG im retarded nevermind dont listen to any of that
Warped
Nismo_Freak wrote:S13 and S14 are completely different.
hey nismo do you have a pinout of the f3 plug?so we know where those wires are soposed to be .the one i found is either right or completely wrong compared to your friends .This is soposed to be a 95 ka f3 plug.
