redtop S13 vaccum hoses
Blade81
Car: 92 S13 hatch w/redtop SR20DET
im doing a redtop SR swap in my 92 fastback and i was wondering if anyone had any pics of their vaccum hoses and where they go cuz mine is missing hoses and stuff and i dont know where they go to. ive already clicked the search button and i found nothing. so i just need pics of hoses and where they go to thanks.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
there is somehting around here some where. i think chekc out the FAQ at the top of this forum
duffman1278
Car: 89 240sx Hatch, the wildcats!
Do you have a canister?? If you don't which I will assume since your running an SR anyways, here's how it goes, but please search next time.
On the bottom of the throttle body you have ONE nipple, you have to cap that off, you don't use it unless you have the canister.
On the TOP LEFT, you put that one in STRAIGHT to your FPR unless your running a boost gauge which you probably should be, than you tee it so it goes to the FPR and Boost gauge.
On the TOP RIGHT, run this all the way across to the turbo side and tee it, one going to the wastegate, and the other one running to your MAF. Some intercooler pipes however have a nipple for a vacuum hose which would run directly to your wastegate instead of being tee'd off.
SpeedRacer1
Car: 1990 240SX, G35
Hijacker
Car: '92 240sx Convertible
'94 F-150
This is listed in our FAQ. Locked
