redtop: no spark, no start
foCk
Here's where I stand with my S13 SR -> 89 240SX swap:
-I've got no spark (stuck a screwdriver in the coilpack and sat it close to the intake manifold)-The original ignitor was bad so I got a Q45 one to replace it which tested good according to the S14 FSM-The ecu came from a running stockish SR but has a daughterboard in it. Diagnostic LED on this ECU says on all the time no matter what.-My coilpacks are good (tested according to 180fan -My cas is good (I pulled it out, spun it and could hear the fuel injectors clicking)-I've got fuel (wet spark plugs)-I've reset base timing multiple times according to the S14 FSM but for some reason I feel like its 180 degrees out
Please give me some ideas on how to figure out my no spark, no start situation
Also if anyone has the S13 FSM or S13 engine wiring diagram i'd love to get a copy
Blown240sx
Car: 1996 240sx
Test to see fi you have volts coming off the ignitor even though you say it tested good. It has to be between the ignitor to the plugs.
foCk
All these test were done by hooking up my spare CAS and turning it by hand.:Voltage at coilpacks - none (~17mV)Voltage at ignitor - mabye (~17mV spiking to ~150mV)
I tested the wiring between the ignitor and the coilpacks and it is perfect however when I tested between the ecu and ignitor I found that all the wires are connected together and also go to ground. Should these wires go like the FSM shows, 4 individual wires never connecting and never going to ground? I'm going to go and tear apart the harness to see if I can find any issues
