redtop ecu input wire?
fenderguitarist
Car: s13 coupe red top
on the the o2 plug there is a brown, black and white wire and o2 input is pin 19 on the code 62 ecu i checked for input voltage at the ecu and it seems like im getting nothing so i want to wire from the o2 to the ecu which wire sends the voltage to the ecu?? one stays a constant 12volts?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
White wire on the car harness. Output voltage from the O2 sensor is only about .4 volts, so make sure that your tester is in the right range.
