eliterit »
https://forums.nicoclub.com/eliterit-u12096.html
Mon Jun 11, 2007 11:24 am
just take a small allen key and grind the tip of it so its flat and sharp, then you can stick it in the part of the ecu connector which holds each pin in place to get the pin to release, then gently pull out the wire which will release the pin.
i had to repin my redtop harness ecu connector to work with a late model blacktop power fc.
if u have a/c you'll have to rewire the a/c pin too.
i didnt bother to switch o/2 sensors, i just unplugged mine.
oh and thanks speedracer for that ecu pinout diagram. you rock
