Redtop clutch slave cylinder.
zenkizen
Car: S14 Zenki
I gotta 95 S14 with a redtop SR20det
My clutch pedal comes back up only half way. I bled the clutch 3 different times. The first and second time was a 2 man bleed with the dampening box removed. the 3rd time was a gravity bleed, but still no luck.
I'm going to swap out the old slave with a new one from kragen/autozone and also go with a steel braided clutch line.
1 - is the slave the same as a sentra SE-R?2 - do you think this will fix the problem?
zenkizen
Car: S14 Zenki
i just found on the SR20 parts guide that the slave can be replaced with a Slave cylinder '93 240sx. so that answers question #1 i think.
zenkizen
Car: S14 Zenki
Oh and BTW, the clutch pedal does come back all the way up only when i punch the gas 70% or more after shifting.
