matt4pl »
https://forums.nicoclub.com/matt4pl-u4587.html
Wed Apr 14, 2004 2:09 am
well, i already drilled them. used a drill press, put a bolt through one hold on the 240 rotors and into the q45 rotors, only hole those two share. then i used the existing 4 lug hole on the 240 rotors to drill the holes in the q45 rotors, after lining everything up and clamping it down. they both fit, if maybe a little tightly, but they fit on the 4 lug. i used a zarconium nitrade bit by craftsman, crazy bit, cant even tell its been used after that drilling. it was $15 though
