REDRIILLING 300zx rotors for 4-lug
SpazmSi
Car: 240sx 13 HB
ok no more 5-lug BS.
How do you redrill the rotor for 4 lug S13. can I lay the old 4 lug rotor on the 5lug and line up any holes, put a bolt the same size as the lug studs and then drill the remaining holes. I have a press and all kinds of tools so that area won't be a problem.
I searched all kinds of combinations for re-drilling, drilling, 4 lug 300zx rotor, etc etc So if this has been covered before please treat me like any other retarded individual and help me into the short bus. Send me a link don't just tell me to search, if you have to flame a little, go ahead I can handle it lol
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah you can do that what you mentioned...
JimLecesse
Car: 1992 240sx Hatchback - SR20DET
I just had my Q45 rotors redrilled at a local machine shop. Cost me 20 bucks for both (fronts). If you don't feel confident doing it yourself, its a quick and easy job for a shop.
SpazmSi
Car: 240sx 13 HB
Great Thanks FolksI may try it, I have the equipment.
Do two holes line up? I haven't bought the brake rotors yet.
SmithSR
Car: 240sx
Two holes do not line up.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Here's a few pics so you can understand how the 4 lug is redrilled. One hole is lined up, but the other three need to be drilled.
One note of caution. If the rotor moves on you while you drill, you can kiss that rotor goodbye because it will be uneven as it rotates while the car is in motion. Given how precise you have to be with the drilling, I'd rather let a professional do it.
image 1
image 2
smokey240sx
you could also go to heavy throttle and buy pre drilled brembo rotors.
