rcboy514 »
https://forums.nicoclub.com/rcboy514-u88574.html
Sun Sep 11, 2011 6:38 pm
I guess it's possible, but with the VHT stuff it tends to look speckled close up if you don't have enough coats. I'm not sure the exact # of coats on mine currently. When I first did them I think I did 5, but last night I sanded them down with some 1000 grit and applied two coats of tint and 3 coats of clear. They were noticeably faded before i painted them, but there was still tint on them when i re-painted.
I would suggest just getting some of bats 3/10 vinyl and then cutting out the reverse light circle, but you don't need to be too worried about not seeing the brake lights unless your state is really strict. Mine look like the pictures in person and you can still see the brake lights easily on a sunny day.
as far as vinyl the cheapest place I've found is vinyldecals.com I got a 12"x24" sheet for $10 and that was enough to do both mirrors and I still had a cut off some extra.
also as a tip to anyone painting their tails, if you are going to leave the reverse area clear you can use the inner diameter of a roll of duct tape as a stencil to cut out a piece of material to cover the light while you paint. It's like the perfect diameter.
