RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Sat May 05, 2007 9:45 am
So I was reading a while back In Turbo Mag, where they did a test on 4 different water wetters mixed with straight distilled water on a Honda.......and was curious if anyone has tried it on their CA?The temp drops were pretty good........Cruising temp dropped 9 degrees4000 rpm cruising dropped 12 degrees5000 rpm hill climb dropped 8 degreesExtended idling droped 10 degreesCyl. head dropped 9 degreesRad. temp dropped 8%
The 3 other brands were DEI Radiator relief, Hyper Lube Supper Coolant, and Juistice Brothers Radiator Cooler. Juistice came in first, and Redline in second. Redline actually did slightly better when mixed with a 30/70 antifreeze/ water mix with Honda coolant.
My question is........is it ok to run a straight water/ wetter mix on a daily driver? One thing they didn't mention, and is my biggest concern, is winter time driving.......it gets in the teens here...........I wonder if it'll freeze?
