REDLINE??
bryantkalagian
Car: 96 240sx
what is the redline on a rb25det series 2? mine has no rev limiter..when i was topping my car out, it just kept going past 7, which i thought was the redline?
craz4240
Car: 1995 240sx w/rb20det
Your tach is probably not calibrated right.
synergy
Car: s14 rb25 s1
agreed when i had my tach not calibrated i could rev to what seemed like 11k. redlines supposed to be 7500 im pretty sure.
bryantkalagian
Car: 96 240sx
so i do have a rev limiter and never hit it??
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I dont know about the S2 but my S1 hits the limiter at 6700rpm. Fully stock ecu with RPM confirmed by Autometer tach and Apexi AVCR.
synergy
Car: s14 rb25 s1
wow 6700? thats low... i dont know man.
And about you having a a incorrectly calibrated tach. I dont really know it sounds alot like thats your issue but you never know.... hows your gearing and power. if your tach is off you should notice less power than what you should have and your gears will be short.
eh?
6700-6800 is about right
synergy
Car: s14 rb25 s1
maybe my ecu has been chipped then hahaha. What can the stock RB valvetrain handle?
eh?
Nobody really knows. Lots of speculation, no proof.I've had it up to 8400 totally stock but had to reduce it due to oil pressure problems.
synergy
Car: s14 rb25 s1
i think mine at 7500 will be alright... im taking the head off of it this weekend we will see what it looks like...
bryantkalagian
Car: 96 240sx
let me know how it looks. haha
Cjmartz2k
Car: Hunting for a '89 GTR now
Where it's going to make power and when you "should" shift depend on a lot of different things/opinions.
Bottom line though, you're not going to hurt the engine by shifting under 7500rpm. I used to shift my RB25 around 7800 with a stock engine and a big turbo all the time and never hurt it.
synergy
Car: s14 rb25 s1
Yeah i totally agree with you. I love when people have dynos and it shows them losing power top end and they continue to rev it up to that thinking hey if 7krpm is good 8k must be better. I was just wondering what i should set mine to. I will for now only be pushing 12-14psi out of the stock turbo but will be upgrading to a to4e (.57T .63 A/r) and around 14psi daily with tune up to 18psi.
rb25det250sx
Car: '96 Nissan 240SX RB25DET powered!!!
if your just goin to run the stock turbo the stock rev limiter is suficient... im assuming your running stock mani, and Dp.. and like everyone else with these car unless there externally gated you will lose boost around 4500-5500 RPM.. only drops a couple lbs but still pulles very hard even when losing boost.
