centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Jun 11, 2007 2:17 pm
Ah good, no light is a sign that I may have the same issue. I fiddled with the wires at the plugs yesterday and went for a cruise. I tried to rev up to redline in third and got the engine cut still at 5250ish rpms. I will test continuity to the ECU tonight or tomorrow. If continuity is good, then I want to test the sensor istself. It kinda sucks 'cause I can really only get to that guy when all is cold or I burn my wrist on the stupid EGR tube or the head. You don't know of a way to test the reading from the sensor do you? Maybe test for Ohms and turn the crank pulley from side to side to move the flywheel teeth a bit? Maybe nows the time to admit I had to replace my stock 5-speed. The inside went to schrapnel and all I could source was an S13 transmission. So I swapped the speed sensor and picked the best looking posistion sensors and plugged them all in. When smog came along, I took the transmission off, drilled two holes, tapped and threaded one and installed a new CAS to clear the code and pass smog. Well, that all worked, but I might not have matched the depth of the sensor perfectly, so maybe the signal it sends is off a bit which is why I would want to test it.
