hey guys and gals got a problem with my budys red top sr20det it stumbles between 2500 and 3000 basically like a on a off switch. It all started when i set the timing to stock (guy had it before had it at tdc
) it didn't do it before but it was very slow go figure. We have adjusted the tps which was at .12 at idle we set it to .48 at idle. then found the ground on the z32 maf going to ?ecu? not body ground was broke in half soldered that back no change. Also found walbro fuel pump plug was burnt up
replaced that still no change. she is not throwing any codes eather. Sadly he has no wide band but he will get one with in the week or 2. The guy who did the swap realy screwed the harness up. please help thanks in advance
list of mods
z32 maf
gt2871 11psi
550 injectors
walbro 255
enthalpy tune
z32 fuel filter
3 inch exhoust and test pipe
list of stuff replaced
another used tps
a good maf
new brk7 gaped to .30
checked coils
changed temp sensor for good one
new fuel pump (walbro)
check timing a billion times
checked timing chain alignment
will check for boost leaks this weekend
