rudee023 »
https://forums.nicoclub.com/rudee023-u4970.html
Tue Mar 22, 2005 6:19 pm
Check the main engine grounds as well as the one going to the fire wall from the head. Make sure the two little ones toward the rear of the intake manifold are tight as well. Check the plugs and wires going into all 4 coilpacks, and if you haven't changed plugs recently make sure they haven't been fouled. If you are running electric fans make sure they are run through a relay and not directly off the fuel pump fuse. Other than that check the obvious again, boost leaks, fuel pressure if you have a gauge, etc...
