Red top Sr w/ oem s18 t28 turbo
AB-R40
Car: 1992 Nissan 240sx SE
Ok. I know many people have been asking this question, but what will I need if I get a S15 garrett t28 turbo? Do I have to get new injectors? Please help!!!
sean@z1
Car: 1993 240sx
just some oil and water lines and new gaskets i have the turbos on sale for 675.00 brand new in the box
AB-R40
really. I thought you need the in/outlet t28 pipes too. i might be interested in your turbo to man. ill keep you in mind.
sean@z1
Car: 1993 240sx
ahh yes sorry i the inlet and outlet are diffrent as well from the S-13 SR and S14 and 15 motors
AB-R40
hrmm anything else? Could you try and get me a good deal? if not its ok man. but 675 for t28 that is a great price already.
sean@z1
Car: 1993 240sx
I can work you up a package deal with everything do you want the gaskets as well?
AB-R40
How much would everything I need for the turbo set up be? such as: Oem T28, Turbo Lines, In/Outlet pipes?
How much w/o the gaskets? Because the one on my t25 are kinda brand new. I replaced it about 5 months ago.
sean@z1
Car: 1993 240sx
178.95 for the oil return hose, oil return tube,the outlet and inlet pipes 675 for the S15 turbo 853.95 plus shipping
AB-R40
Thats a good deal. I'll PM you when I have the money. I should have it by next month on the 17th maybe. but that is a great deal. thanks bro.
sean@z1
Car: 1993 240sx
the turbo went on sale yester day and they are on a 30 day sale just so you know
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
you can use s13 piping if you buy the clocking plates from STANCE
AB-R40
ok man
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
wish I could afford a t28...
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
What you will need really depends on the boost level you are running, I would recomend a wideband AFR kit so you can make sure your not going lean under boost...the s14 originally had larger injecters then the s13 to compensate for the larger turbo's capabilities
