LOL When the engine is running the fuel pump is runningDLYNNW wrote:i do not have to worry about the fuel pump catching fire do i from running constantly while the cars on.
ok all the fuse under the hood are fine and relays. but im still getting no power to the fuel pump harness in the rear hatch and bye jumping the relay will this effect putting in any electronics for fuel mods or gauges. lol plus i know the fuel pump shut off when the car does and turns on when it does. but i thought the relay kept it fro getting to hot and catching fire.Sileighty_85 wrote:
when you shut off the engine the fuel pump turns off
Check all the fuese
You need to open up your ecu...I bet you have a burnt spot in your computer...there are topics on nico on how to fix the ecu issue. If you jump the fuel pump you could cause other issues if done improperlyDLYNNW wrote:u think it could be the ignitor chip but wht your saying is that it will b safe to jump it and there will b no interfierence with electronics for fuel mods being hookedup
d i just buy a new ecu for the red top on ebay or does it need to be for that specific motor or could it be any redtop ecu!!!240life wrote: You need to open up your ecu...I bet you have a burnt spot in your computer...there are topics on nico on how to fix the ecu issue. If you jump the fuel pump you could cause other issues if done improperly
if, and when you open up your ecu and determine whether or not it is damaged is when I would look for a s13 ecu red or blacktop...as long as it isn't the typex you will be ok.DLYNNW wrote:could i just buy a new ecu for the red top on ebay or does it need to be for that specific motor or could it be any redtop ecu!!!
ok bro. i opened the ECU and nothing its all look great. so im going to test the relays next.240life wrote: You need to open up your ecu...I bet you have a burnt spot in your computer...there are topics on nico on how to fix the ecu issue. If you jump the fuel pump you could cause other issues if done improperly
