Red top paint code
score
Im repainting my valve cover due to all the nasty scratches in it. Any one know the paint code of the stock red top?
nismostate
Car: all sorts of motorsports
good question. im interested tooo.
msaskin
Car: cars, computers, skiing, mountain biking
Go to a paint shop and have them color match it.
My car is painted a similar color (a bit darker though).
~matt
BaliLover
Its a 3 stage paint, Candy Apple red it looks like. What this means is that it is first painted silver, then a transparent red is sprayed over the top of it, then a clearcoat is applied. This allows the light to reflect off the silver, but look red due to the tint.
IF you are good with spray can, Duplicolor makes an Anodized red paint that works this way that looks pretty darn close. You strip the existing paint from the VC, clean it really well, sand it with 600 grit sand paper, paint it silver (as many coats as it takes to fully cover), then spray light even coats of the red over this, making really sure not to run or be too dry. You apply the red until the color you want is achieved. Once achieved, clearcoat away.
Just be sure to read the can for clarification of drying times, spraying distance, etc.
score
Thanks for the info!
Im no Krylon Kommander, but I bet Ill be able to figure it out.
Hijacker
Car: '92 240sx Convertible
'94 F-150
carlos, call the guys at JGY customs (www.jgycustoms.com) they powder coat valve covers, so they probably would know the paint code for the VC
freshsx
Car: Nissan 240SX 1992
I have a few scratch on mine due to the straps now I see the silver... I just need a bit of paint that will match properly. I don't want to paint the entire valve cover. The paint is off probably for like 4 inch max.
Anybody have the paint # ??????? plzzzzzz
