Red Top in S14 wiring
Ace
Car: S14
When installing a S13 Red Top in an S14 chasis how do you go about wiring. Do you use an S13 wiring diagram or use a S14 diagram or both. I f%$#ing confuse myself sometimes.:confused:What do I use.
SpeedRacer1
Car: 1990 240SX, G35
What ECU are you using? S13? Id use the wiring diagram that best fits the ECU and Harness.
Daunttless
Heh, thats part of the problem. : ) You need to use the redtop S13 wiring diagram mated to the S14 240SX diagram.
Ace
Car: S14
That is what I thought, is there any diagram like that around or do you just guess and check.:confused:
SRdS14
Car: Workin on my car, chillin with friends, basically whatever...
yup..u gotta get it wired, like dauntless said. i personally did the Jim Wolf Technology ecu where i can use the ka24de wiring harness, along with the ka ecu (JWT)~Scott The ecu is like 600 bux, plus a distributor from a rwd silvia Q, 200. i took the expensive way out...
