Red Line SI-1 Fuel System Cleaner?
PachoC
Does anybody have any experience using Red Line's fcomplete fuel system cleaner? It is supposed to be a synthetic product, oxygen sensor safe and according to some reviews, very effective.
Below info taken from their site:
Complete Fuel System Cleaner contains detergents and a synthetic upper cylinder lubricant which will help clean the intake valves, pollution control valves, combustion chamber deposits and carburetors.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive used it, and got better performance out of BG44k...
Falkdesigns
Car: 1998 Q45t ~ EXE
...but, the Redline costs 5 bucks and you can get it anywhere (parts shop). My mechanic sells BG44k, but he recommends Amsoil fuel system cleaner over the BG, I was gonna get some from him.
PachoC
After using BG44K I believe you need to change the oil. Is this correct? That doesn't seem to be the case with Red Line. Can you confirm?Tks!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
I've used it the day I drove my Q home which was an 800 mile ride. It works, but nothing incredible. BG is highly respected especially since Porsche endorses it. I never tried the Amsoil one, but have used Amsoil synthetic ATF in my Mercedes and it works great. The only products that I used to use on a regular basis for fuel inkection cleaning are from Luqui-Moly and you can feel the difference the very first time you out your foot on the accelerator. It was the Jectron and Ventil Sauber that I used to buy often.
elwesso
2007 BMW M Coupe
PachoC wrote:After using BG44K I believe you need to change the oil. Is this correct? That doesn't seem to be the case with Red Line. Can you confirm?Tks!
no, you use it the same way you use redline.
I just say use 44k because its the only stuff ive found that works (noticeable difference), so why waste money on stuff that doesnt work as good... might as well not use anything than use something that doesnt work... "nothing" costs less.
Lino, where do you get that stuff...?
Qproject
this bg44k, do u just pour it into your topped off gas tank?
elwesso
2007 BMW M Coupe
best to dump it in before you fill your tank so it mixes really well.
PachoC
Where is the best place to get BG44K? Apparently is not sold by retailers or autoparts stores. I even tried a couple of car dealerships but they (supposedly) had no idea what I was talking about.
elwesso
2007 BMW M Coupe
I usually get mine from Joe or ebay.... You have to get it online, somehow.
Q45tech
Use BG web site to findhttp://www.bgfindashop.com/bgservices/fuelair.htm
If the stuff you buy is so weak you don't have to change the oil after you use what are you really buying?
Bg makes an ultra induction cleaner that will poison the entire staff if you use it inside a closed shop and the vapor will strip the paint off the walls.......this is a product you won't find me mentioning here but I use it annually on my 311k Q and real basket cases [the emergency room].
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
PachoC wrote:Where is the best place to get BG44K?
Joe had a killer price special that expired today.
lino
In Germany it's called Liqui Moly and in the US it's called Lubro Moly.
Mr. Gary Boyd was the official North American supplier. I haven't called him in a while, but here is the telephone number I have: 1-800-223-1634
Here is the official website:
http://www.liqui-moly.de/web/l...flash
Click on the American flag for English
Here are 2 US resellers:
http://www.etyparts.com/lubro%20moly.htm
https://www.olyonline.com/Lubromoly.asp
Other links:
http://www.formula3.cc/content/view/13064/263/
http://www.grandprix.com/ns/ns05896.html
elwesso
2007 BMW M Coupe
hmm, its slightly cheaper than Joes 44k, i may give it a try next time im due.
heywier427
Car: 91 Q45
curious as to why you wont mention it here? saftey concerns? is it the bg pressure kit cleaner?
if i could use something better than 44k or better than doing the bg kit every year id really really like to know.
