I would go to AutoZone and get you Alternator checked. It sounds like an issue. If you have an voltmeter, you could have someone sit in the car and press the brake while the headlights are on and see how low the volts drop. If below 12v you got a problem. The voltage regulator could be on the way out.DominickJ30 wrote:Not completely, the connections are old and loose, somtimes when I am at a stop light and have the brake applied, the warning light blinks like mad.
