Red Headlight Warning Light
AZ300ZX
Car: 93 300ZX TT
Help please....Headlight warning light glows red when brake pedal depressed, all light appear to be functioning...1993 tt
nissanfreak12
Car: 92 300zx 2+2 TT
There is a relay box, Green driver side hatch area behind the panels, usually something goes wonky in those if that light comes on.
OR
If you just replaced the bulbs in the 3rd brakelight and did not get them from the factory, this will cause the light to come on. I think the parts store ones have the wrong wattage.
nexus08
Car: 1990 300ZX NA
Yeah, for some reason Nissan decided to put in a sensor that measures current through the bulbs. If one is not making good contact, or like freak said, is the wrong bulb, the light will come on when you press the brake.
Remove the bulbs, clean the contacts, see if the problem goes away.
AZ300ZX
Car: 93 300ZX TT
Thanks for the help. I'll try it and let you know but traveling for the next week
AZ300ZX
Car: 93 300ZX TT
Had to buy factory bulbs,but problems solved. Thx
