Red ECU light stays on...
govtworkhorse
Car: 95 240sx SE, 95 240SX, 91 Festiva (DD), 03 GSX-R 600
As the title states, the red light in my RB20 ECU stays on all the time. I am trying to track down a wiring issue that is causing a h3ll of a draw on my battery. I noticed this so I thought some of you wiring geniuses might know why that is. I was going to go up tonight and work on it but the garage is like 30 degrees I think and I figured I post this and hit it in the morning.
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
ok to fix this problem u need to unrap the wiring for both the green relays near the ecu, no turn the ign. on and feel for them to click, only 1 will be clicking, now locate the orange (iirc) wire running between the 2 relays and to the ecu, cut the wire that is running to the relay that IS NOT clicking. problem should be solved.
govtworkhorse
ok I'll try that in the morning and let you know whats up. Thanks.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
make sure the white/purple wire near the passenger side engine bay fuse box is seeing switched 12v and not battery +.
govtworkhorse
So I cut the orange wire from the relay and it appears to have solves my problem. ECU light goes off when key is off and battery has held a charge of 12.64V since around 6pm. I will check it in the morning for the final test. If the car starts I'm happy.
driftmyke
good to hear man. it will be fine my car had the same problem and now it can sit all week and still start right up
HiTemp240
Car: 1990 Nissan 240SX
I don't post on here much but I just fixed my car with this advice, you guys are incredible so Thanks! I had been unhooking the battery at nite
via quick lever on battery. I look to see my car running better too now since I hear the ECU learns how to act and behave as you go wich won't
happen if I unhook it every nite.
