Red box on positive wiring for battery
Bradle2695
Car: 2001 Nissan Pathfinder. BONE STOCK
So my wiring to my positive post is pretty much gone and I want to re do it all. I'm going to just run all the wires together into one clamp but I need a new one of the red boxes because it runs to the fusebox and I think it has fuses in it. The wires are disconnect able from the back of it I think, what is this part number or what's it called, I cannot find it ANYWHERE
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
I deleted mine, its just a piece that makes connecting to the battery easy, there are no internal fuses or anything to it, I just ran my own (bigger gauge) wires straight from the fuse box to the battery with the new terminal on the end.
Bradle2695
Thanks you so much
Sonoiz420
Car: 1993 Nissan sentra
Ive had the same problem so I can delete the red box and just run the alt wire with the positive into the terminal?
