Negative... Its just the absence of yet another feature that we dont get on this side of the pond...domo325 wrote:It's an air vent, helps relieve pressure underneath the car and improves fuel economy. This is according to a review I just watched on the Rogue 2015.
The shape of the one you posted wont work in that spot... Look for the OEM T32 Xtrail rear fog lamp... Its made for that hole... It will fit right in. If you dont want to use it as a fog lamp, just wire it to the brake lights.frijolito wrote:Bugger, I was thinking of installing one of these in it as a extra bottom brake light..
http://www.amazon.com/Vktech-Triangle-T ... +brake+led
Anyone tried that?
If it blocks the air flow maybe I shouldn't...
Your post seems to be cut off. Anyway, I believe the rear fog light is mandatory in the EU, but the 2nd gen Rogue's are built here in the US where there's no such requirement, so I'd venture to say the wiring isn't there.outtolearn88 wrote:Anyone know if the wiring is in place for it ?
The
Hey XD1XD1 wrote: ↑Wed Aug 09, 2017 10:13 amDoes anyone know what replacement bulb this light takes? I can't find anywhere that lists a bulb number for the x trail rear fog light, and to do the upgrade on my Rogue I need to get the correct socket/bulb for it.
Here is a close up of the housing from the amazon page - almost looks like a 194 / 168 but seems not quite right to me:
https://vignette1.wikia.nocookie.net/xd ... _14-16.png
