Recommended Tire Pressure Info
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Hey guys I have 225/45R-18 91 W Falken Ziex ZE-912 Tires and was wondering the what i should set the tire pressure at.
xeene
Car: 2008 altima, 2007 fx35
40psi if you want good mileage and 35psi if you want softer ride.
Spoolin4days
Car: 03 Spec V, 92 Sentra 2dr
xeene wrote:40psi if you want good mileage and 35psi if you want softer ride.
Would 5 psi really change the mileage?
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
It all depends on your tire. Max pressure is written on the sidewall of it. Set it about 10 psi below that number, and your set.
xeene
5psi difference can effect your mileage by about 2-3%. not that much unless you're a hypermiling fanatic
CoutureCoupe
Car: 2010 Altima Coupe 3.5 SR
When I installed the tires I set the pressure at 35 psi for each tire. So today, I went to the dealership to reset the light for the TPMS. The light appeared off when I left, then when I got onto the highway the light started blinking, then steady. When I got home I checked the pressure on all tires and the fronts were at 40 and the rear are both at 39. They obviously put air in the tires without consulting me or letting me know for the future.
I do want to add that the ride was noticeably rougher on the way home and I felt every bump in the road. Does anyone have any suggestions to what may have happened or why they may have added the air and lastly what the pressure should be? I have Yokohama yk520 225/45/18.
Thanks
Zerep
Car: A/C 2.5R
it might be that your drive home heated up your tires and gave you a higher reading since air expands as it gets hotter. im pretty sure that tires read higher psi when then warm then when there cold. your drive home might be the culprit
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
and i always set mine at 35psi
