nsrZ32 wrote:I run the following in mine....
-Redline Synthetic MT90 for the transmission-Redline Synthetic 75w90 or similar gear oil for the differential-Mobil 1 Synthetic motor oil
I can vouch for Redline MT90 (75w90) gear oil. I had a tiny crunch at a redline shift from 3rd to 4th. Changed my fluid to Redline MT90 and that is all gone.
As for motor oil, I current run 10W40 Amsoil, but I will be switching to Mobil 1 10W40 full synthetic soon. No bad experiences here, just changes in my loyalty and other things that wouldn't affect your decision here :P . lol
Yea, but 100,000 KMS is the interval at whick you want to change the transmission, diff and engine fluids.
Refer to this image from the service manual for other items to inspect/change:
http://www.300zx-twinturbo.com/s.manual/ma/004.gif
Ensure that all 80,000 KM items are in order too.
100,000km is also the Nissan recommended interval at which they recommend replacing the timing belt. This might be fine to not do for now, if it has not been changed before, but I wouldn't go beyond 120,000 KM without changing it. After all the engine is interference, meaning if the timing belt breaks or skips (skips so far, not just a tooth or tho) a valve will collide with a piston and you will be out an engine.
Check the timing belt cover to see if there is any sticker/plaque/markings indicating the timing belt was done.
I have a JDM Z and mine has one (mostly in JDM scribble lol) saying mine was done at around 62,000 km if memory serves me correct. Don't know why, but I would have had to do mine quite recently if it had not been.
