Recommended AFR for RB25
totoro001
Car: Changes Constantly
Hey guys, I've done a bit of googeling and searching and I was curious as to a safe and recommend AFR for the RB25. If this has been talked about 100 times, please hit me with a stick and link me to a thread on the topic. I've seen a bunch saying around 11-11.5ish, but I was curious as to optimal before I start tuning.
On a side note, what does everyone think of the DynoJet wideband?
Modified by totoro001 at 1:12 AM 10/25/2008
gawdzilla
Car: none
stock turbo? probably high 11's. big power and boost probably low 11s
totoro001
Yeh, it's currently got the stock turbo, but I'll be turning it up to around 10psi here in the next couple weeks.
Well hmm that kind of sucks, I just baught this car and it's running lean (quite lean in fact) though it's not knocking, the engine seems to be running a bit hot. I'm hoping it didn't jack with any of the forged internals.
240z4u
Car: '95 Nissan 240SX
11.5-11.7 at typical boost levels with stock turbo as ^ said.
A wideband is a wideband, as long as its accurate. Keep in mind if you have an exhaust leak up stream, you won't get an accurate reading.
Evan
