Well, I guess there is no easy way. Since it doesn't look like anyone has tried messing with the stock base system, I decided to dust off my multimeter, take the measuring tape and do investigative measuring myself. If anyone is interested, here is what came out of it.
First, I wanted to make sure that my multimeter skills were still ok. Took out a Sony shelf system speaker rated at 6 Ohm and got this result:
Not bad. Now to the actual speaker. Disassembled the door panel again, yanked it out and here's what it says on the back:
Still no sign of "Bose" but oh well.
It says it's rated at 40W and 4 Ohm. Is it?
Close enough. 4 Ohm aftermarket set should be a good fit.
Now to the measuring part. Looks like there is about 1" (15/16"?) between the mounting plate and the glass slider/channel (not sure what it's called):
And about 1 7/16" to the actual glass itself.
A little less than 1" of extra depth on top of whatever the speaker assembly is (shown below). However, I get the feeling that due to the weird 6.5" speaker position (it's positioned slightly to the right), clearing a larger 6.5" magnet would be more difficult than clearing the same magnet size on a 6x9".
On to the actual speaker assembly. ~1 7/8" of depth:
I decided to measure how much the stock speaker magnet (surprisingly basey for a magnet like that) sticks out. Around 0.5" or so:
So far it looks like anything with ~2" depth will clear without a problem. 2.5" is a possibility but a spacer may be required. On thing that worries my is that if I re-use the OEM 6.5" housing, I don't know whether I'll be able to mount the speaker right on top of it or if it will sit a bit below, like the stock one:
I wish I had measurements for Bose 6x9" speaker assembly so I would have an idea of what kind of 6x9" can fit there. Either way, looks like 6.5" is the safest route to go but 6x9" is still very appealing
