recommendation on vacuum caps?
C4ORCE
Car: 1990 2+2 with JDM TT swap
hi guys, my twin turbo keeps destroying vacuum caps in some way another. either it rips the top off, splits completely down the side from top to bottom or blows completely off. its not fun to drive down the road just so i can replace vacuum caps when i get home. :bs: Is their something stronger than these soft rubber vacuum caps i can use? :confused: silicone maybe? any suggestions would be appreciated.
agent4573
If you're splitting them down the side, you're using caps that are too small. If you're blowing them off, they may be the right size, but under high boost you should probably run a spring clamp on all tube caps.
They make upgraded caps, but the hardest part is finding them in small quantities. Most places want to sell you at least 100, but I'm sure if you looked around amazon or google you could find individual caps for sale. The EPDM, vinyl, or silicone caps would be an upgrade over anything you'll find in autozone or pepboys.
http://www.amazon.com/Black-3-2f8-22-Vi ... B001TX4724
http://www.clipsandfasteners.com/Vacuum ... _s/201.htm
http://www.stockcap.com/store/caps.html
ThisIsSparTTa
Car: 91 300ZX TT 2+0
How much boost are you running? At 14PSI, I've had no issues, just run of the mill auto store caps. I put almost all of mine on with a small zip tie to make sure it stays in place.
C4ORCE
just stock boost. its not so much of them blowing off completely its more of the tops being ripped off. i was trying to find stuff last night when i ran across a thread on an RX-7 forum and they recommended these
http://store.034motorsport.com/silicone ... -caps.html
i'm not sure how many are included in that price it doesn't specify.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Personally, I used vacuum hose the silicon-ed a screw into it to cap it off.. that is until I welded them up :)
C4ORCE
Ziggy1621 wrote:Personally, I used vacuum hose the silicon-ed a screw into it to cap it off.. that is until I welded them up :)
That was my next thought. I'm gonna try these "boost" caps and if they don't work i guess I'll whip up some epoxy.
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
The boost caps will work, but they will dry rot, crack, and product boost leaks over time.
C4ORCE
Ziggy1621 wrote:The boost caps will work, but they will dry rot, crack, and product boost leaks over time.
Yea this is probably true. I guess I'll just seal them off completely to prevent future problems. Thanks Ziggy :cheers:
C4ORCE
Hey guys i ordered some of those boost caps if any one else was interested. I figured it wouldn't hurt to try it before completely sealing the nipples off. They finally came in UPS today and wanted to show the difference.
Top cap is a standard vacuum cap the bottom one is the boost/pressure cap
Left cap is a standard vacuum cap the right one is the boost/pressure cap
As you can tell their is quite a difference in the two but also note that i purchased 3 caps and my total with shipping was $30....so they are a little on the pricey side. I'll put them on tomorrow boost it hard and see how they hold up lol :bigthumb:
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
I've used the same silicone ones with 8mm spring clamps. Hate to say it, but I bought the cheap eBay brand, 10/$5 IIRC. No issues so far.
300ZXttZMAN
Interesting they def look durable judging by the size alone... If you have any problems post up so people know for the future.
C4ORCE
300ZXttZMAN wrote:If you have any problems post up so people know for the future.
Will do man. I haven't had a chance to drive it yet :frown: but when i do i'll let you know if they hold up.
