After reading all the referenced posts, I really don't understand exactly WHY people feel the need to add an additional Hayden or B&M 70268 to suppliment or bypass the original transmission heat exchanger in a 90-series Q45.
Of course, I can infer the problem was the factory heat exchanger was inadequate ... but what particularly was the sympton or damage that clued you into the fact you need a better transmission heat exchanger (besides a hot shift lever)?
I do see statements such as "The factory cooler actually works as a heater in the summer when the coolant mixture is warmer than the preferred operating temperatures for the transmission. " But what is the symptom if the transmission fluid gets too warm in the summer? And how frequently did this symptom occur in 90 Q45 models?
Interestingly, there was little mention of the automatic transmission oil cooler (other than a minor reference to the AT oil cooler pipes) in the AT section of the 90 FSM, so, I am looking to Nico for further guidance.
It seems the B&M 70268 & 70264 (better cooling) from
http://store.summitracing.com (store.summitracing.com) are referenced the most:70268 Fluid Cooler, Transmission, Plate Type, Black, Aluminum, 7 1/2 in. x 11 in. x 3/4 in., $45.88 70264 Fluid Cooler, Transmission, Plate Type, Black, Aluminum, 6 in. x 11 in. x 1 1/2 in., $49.88 but that was on a mix of model years.
Do both fit nicely in the front-of-radiator-after-condenser location on a 1990 Q45?
Also, every once in a while an "external filter" for the transmission fluid was mentioned in passing. Is there such a thing (I thought the transmission oil filter was inside the transmission)?
Another question that arose is whether there is a power-steering heat exchanger or not. It was cryptically referenced in the threads but I don't see anything about it in the ST section of the 90 FSM ... so I'm not sure if it exists.
