Recommend Plug Wires: ???
240sxJay
I need to get plug wires, i'm wondering if i should just buy ngk wires?
I've seen
AccelMagnumObxBoschNGK
....is there really any difference?
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
Basically, you get what you pay for, but if you are mostly stock, you don't really need the high dollar stuff.
BadMojo
Car: 2007 Mazdaspeed 3
niznos wrote:Basically, you get what you pay for, but if you are mostly stock, you don't really need the high dollar stuff.
I've seen many very reputable sources vouch for OE wires over all the aftermarket stuff, FWIW.
240sxJay
Lol really? I was just thinking of getting NGK wires..can't go wrong with ngk can you? :)
black s13
get OEM, its the only way to go.
ricebike
2002 Quest
2005 Altima
eh, but w/ the SOHC design, most aftermarkets can be had w/out the DOHC design flaws... <popping off from the valve cover>
Plus, me gets lifetime warranty on some of those manufacturers... & most are in 7mm thickness... i guess that 8mm Accel's or some other 'high performance' brand will make it that much easier for the spark to travel to your plugs...
black s13
OEM is seriously what you want. all the high power KA guys use them, the work perfectly.
and what DOHC design flaws do you speak of? my wires never pop off, Nologys with NGKs.
ricebike
2002 Quest
2005 Altima
oh, someone bought aftermarket wires for a DOHC as well as aftermarket plugs... it was one or the other that was causing it to pop off...the boot wasnt holdin tightly to the spark plug end. Can't recall if it was the boot's clamp problem or the spark plug end's problem...
But OEMs the way to go if u gotz $
240sxJay
I went with NGK wires and NGK Iridium Plugs, that should be ok?
black s13
yeah, NGK is good quality, but i would still recommend OEM wires. i only have damn $175 spark plug wires because i didnt have any, and i got them for $20. went from borrowed autozone specials, to nologys and noticed no differance at all, defenitly not worth $175.
sk8erguy1501
Car: 90 240sx KA24DE
Like they said before, if you aren't running a boosted 240....its really not worth it to buy nologys or expensive maganor. There is a set called Aurora 8.5mm from http://www.pdm-racing.com for a reasonable price. My friend has these on his 95 and they are great. Im ordering up a set today.
BadMojo
sk8erguy1501 wrote:Like they said before, if you aren't running a boosted 240....its really not worth it to buy nologys or expensive maganor. There is a set called Aurora 8.5mm from http://www.pdm-racing.com for a reasonable price. My friend has these on his 95 and they are great. Im ordering up a set today.
Guys are making some *serious* power on turbo set-ups with OE wires. I still say, go with OE. Just my opinion.
Drifterxl
Car: 1990 240sx FB
i spent 50 bucks on 8mm taylor spiro pro's for my near stock ka24e and they kicked the sh*t out of my OEM wires.
gogg
Car: 89 240sx silver hatch (burrito)
Drifterxl wrote:i spent 50 bucks on 8mm taylor spiro pro's for my near stock ka24e and they kicked the sh*t out of my OEM wires.
Maybe your OEM's were in horrible condition...
Drifterxl
Car: 1990 240sx FB
well they looked to be in fine condition, and i wasn't lacking power or response, thats for sure..... i just wanted to upgrade it anyways, and i did, and there was quite a difference.
