Victor »
https://forums.nicoclub.com/victor-u94029.html
Sat Jul 11, 2009 5:13 am
The NICO list doesn't show code P0158, but the FSM for a 2000 Q45 does show it, and its supposed to be the rear bank 2 O2 sensor. Where are the bank 2 sensors, driver or passenger side of engine or where? How hard are they to get to? Joe wants I think around $140 for an oxygen sensor, but a mechanic said he could get OEM Nissan sensors for $80 each, and install them for $40, does that sound right? BTW, the FSM said the rear sensors are not used for engine control under normal circumstances, does that mean one can put off ever replacing them? An OBD forum thread said Infiniti P 0158 PIDs are often false faults, and something else can be causing the problem other than the O2 sensor. The FSM says check the wiring first, then the sensor, then intake air leaks, then fuel injectors and fuel pump. The intake air leak part seems stupid, as the rear O2 sensors are connected to the exhaust, not the intake.
