niznos »
https://forums.nicoclub.com/niznos-u14767.html
Wed Apr 07, 2004 12:11 pm
I told the parts guy to get a 95 300zx turbo fuel filter and got what I needed. Like I said, no gain unless you've got upgraded fuel systems parts like high pressure/ volume pump and the like, otherwise there's no need for it. Just your choice.
I use the standard NGK V-powers with my NOS, intake, exhaust, Nismo cam, etc with out suffering any ill effects. Those extra prongs are really just a gimmic if your car is not hard tuned with some form of forced induction and the like. Think about it, electricity takes the shortest path. It will only shoot across to the ground electrode that has the shortest gap, even if the differences between the ground electrodes are millionths of an inch. Those extra prongs up the reliabilty of the plug sparking at all under super high RPMs and super fast intake/ exhaust flow, since fast flow can actually blow out the spark. No need to worry unless your car is seriously modified. Besting thing is, only about a buck fifty for NGK V-powers.
The dealer's fuel injection services are really expensive. If you are needing it, you should try the old Seafoam first and see if you can save a lot of money first. It's only $6. 1/3 in the intake, and the other 2/3 in the tank and then fill it up. There's plenty of stuff on that in this forum.
