c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Sun Aug 21, 2005 2:10 pm
12.8 seems a little high to me. I would probably shoot for 11.8-12.0 max. As for the headgasket, pressure is pressure. Whether it be a T28 or a T88. It may flow more, but the pressure is the same. Also, are you going to use an OEM set of head bolts or switch to ARPs? With the stock head bolts and a stock gasket, I would be leary of exceeding 15psi. With some ARPs and a stock gasket I think 17-18 could be run safely with good tuning.
