navigator336 »
https://forums.nicoclub.com/navigator336-u176308.html
Tue Jan 11, 2011 5:26 pm
Thanks Q451990 and Steve The Tech,
I got the seat out no problem. The seat frame was tight to the body so I don't think that is the problem. I suspect the problem is the strut. I didn't take the seat frame out to get to the internal strut mount though. I had both struts replaced recently and I first noticed the noise when leaving the mechanics shop. He turns the radio off when he works on the car and I always have it on, so it is possible the rattle was there before he replaced the struts and I just didn' notice it . I took the car back to him and he said the strut was tight but thought the rattle might be coming from the auto trunk opener/closer. First let me say this about the mechanic. He is a really good really honest independent guy that works on most vehicles, but probably not too many Infiniti's. I totally trust what he says. I took the car home and a couple of weeks later removed the s panel inside the trunk to get better access to the opener/closer. Yes, it could rattle so I disconnected it from the trunk lid and then greased the heck out of it. The rattle was still there. I then immoblized the opener with foam padding and twine. The rattle is still there. I thought if I could remove the seat and quickly fix the problem this would be a lot easier than going back to my mechanic. Taking out the seat frame to get to the strut mount looked to be more trouble than making an appointment and taking it back. I just can't find anything else that might be causing the rattle.
Thanks again for your suggestions.
