Recirculated BOV
freakyjason
Car: 1990 240sx
This may seem like a noobish question (i did search, trust me) but just try to show me a little mercy. How exactly would you go about recirculating a bov? Does the car really bog down and run rich during shifts because the mafs is re-reading the blown off air under the hood? I am looking into buying an sr'd 240 off my friend (real cheap) but the bov (ARC) is vented to the atmosphere. It runs okay though but id like to recirculate it. I have wikipediaed the topic too so im kinda stumped. Pics would be very helpful too. Thanks.
Sabot
Just run a hose from the bov to the pipe in between the maf and the turbo. If the car is running good why mess with it? let see some good pics of the engine bay so we could better help you.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Recirculateing blowoff will take air from the intercooler piping and vent it between the MAF and the turbo itself. This keeps the MAF from "rereading" and also helps keep the turbo spooled between gears.
Goodlord Sabot you beat me by a few seconds! lol
freakyjason
Car: 1990 240sx
Sabot wrote:Just run a hose from the bov to the pipe in between the maf and the turbo. If the car is running good why mess with it? let see some good pics of the engine bay so we could better help you.
Does the hose actually run from a piece or valve on the bov or is it in the piping before the bov? Do you have to "custom fab" a fitting on the piping after the mafs to fit the hose or is there already a place? here is the only pic i got. If you need a better one, i can snap a few off tomorrow and post em' up. Maybe some one can point out what you guys are talking about using ms paint or something.
Thanks for the quick responses!
http://i72.photobucket.com/alb...1.jpg
Modified by freakyjason at 4:51 PM 7/26/2007
Sabot
straight from the bov to the pipe after the maf. Can't see the pipe too good but if the pipe don't have a fitting take it and get one welded.
freakyjason
Car: 1990 240sx
You mean sorta like this?
Sabot
yes sir...just like that
freakyjason
Car: 1990 240sx
Thank you very much for the help. One last thing though, if there is no fitting for the hose there, can it go across onto the piping going into the intake manifold? Thanks again man, very helpful. ive been trying to figure this out for hours.
Sabot
No..
freakyjason
Car: 1990 240sx
Could this possibly cause the car to stall when the rpms are dropping off from boost when the car is coming to a roll or stop? Is this also what makes it run rich in between shifts? Cause that is what his car is doing. I wana make sure i at least have an idea of where to start when takling these isues.
Sabot
stall? yes it could be, usually it is. You could fix it by rec. the bov or a SAFC2 could fix it too like what I'm doing. The rich part in between shifts I think is normal too. How you know? wideband?
freakyjason
Car: 1990 240sx
How do I know it's running rich? Puffs of back smoke when shifting or letting off the gas when the car is in boost. Im assuming that this means it's running rich.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
so how would you recirc an hks bov? im gona do mine but i dont understand how i would attach a hose to it lol i thought i saw a thing for it befor but it might have been a custom piece
