marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Sun Mar 13, 2011 8:39 am
I suspect he was performing a boost leak test. I would think it would most likely be hoses, not the valves. The valves tend to work well and having both of them fail at the same time, just doesn't make sense.
You can get a set of used recirc's fairly easily. Many pull them out and go with blow off valves instead. Z1 also is now selling silicone recirc hoses that should eliminate the cracking rubber on the OEM's. I would look into that. But first, pull the panel and give it a good visual. Make sure everything looks like it is tight and inspect the rubber recirc hoses for cracks.
