Recharging - do I have an AGM battery? - '16 Rogue SL
digital_rogue
Car: 2016 Rogue SV AWD + tech/ moonroof pkg
I want to recharge the battery on my 2016 Rogue SL, which has been sitting idle too long. The instructions for my charger ask me to confirm the battery type first. There is a different setting on the charger for AGM batteries. I still have the original battery. Is it an AGM type?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Well first of all, AGM stands for "Absorbent Glass Mat", which is a type of a separator used in the construction of the battery. AGM batteries have a relatively small amount of acid, which is absorbed by the AGM separator. This allows the battery to be spill-proof. AGM batteries are also sealed, allowing them to be maintenance-free.
AGM batteries cost more and are generally not standard equipment on run-of-the-mill cars. Unlike traditional lead acid batteries, AGM batteries are sealed, meaning you cannot top off the water levels. If you can pop the cell covers off then it's not an AGM battery.
Return to “Rogue Forum”
