Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Mon Apr 12, 2010 5:59 am
Matt, I wouldn't worry. What are you going to do what sounds like limited facilities? Vent some refrigerant? 99.9 % of compressors new and rebuilt today come w oil, any reputable supplier will tell you type and quantity of oil in compressor.
Ester is more compatible w mineral oil than is PAG, but unless you remove evap, flush and remove all oil from evap & condenser, replace dryer, you are only guessing at oil qty remaining in system. I don't know about ester/PAG compatibility.
So given that you are DIY (and don't get me wrong, I believe in DIY) with apparently limited facilities, what's done is done, and unless you're prepared to do a complete flush, purge, and evacuation, if you are getting good results, I wouldn't worry too much.
You may want to write down date, qty and type oil and refrigerant used, etc., so that if you have to go through it again, you will have records. Most shops doing r12 to r134a conversions record such on a label.
