bunda4th wrote:From the looks of it. You will have to lose that racing line strut bar. supposedly with coilover the strut bar will not fit, A member have the BC Racing coilover and the racing line strut bar does not fit at all.
Also the camber bolt is not suppose to go above the top hole if that is what you are asking. If you can fit the coilover and bolt it on then you are good. I can't get to my camber bolt at all and it does not reach to the top of the hole.
I also have the BC Racing coils.
I dont believe the strut bar was a problem (yet) haha, my mechanic had to first disassemble my OEM suspensions first so we did not even get far enough to encounter the strut not fitting. Wait... so your saying the camber bolts are not suppose to go above the top hole (in some cases?) do you have a picture on what it may look like. I really don't know, it was taken to a professional to be worked on. I am thinking about doing it myself now. THANKS A LOT I will be waiting for a reply from ksports.
