infinitgkid »
https://forums.nicoclub.com/infinitgkid-u68775.html
Sat Nov 01, 2008 5:43 am
These are all good ideas that you should check for, but if the belts are tightened properly as others have suggested and you still hear the squeaking sound I suggest that you check to make sure that you don't have any moisture/dirt between the pulley and the belt.
This happened to me last year, and I had to take it to the dealership to get dealt with. I too thought it was a tightening issue with my belts until I checked it at a friends house only to find out that they belts were on tight enough and that it was moisture/dirt issue.
Whatever the case though, good luck
